GPU help
Go to solution Solved by lmeneses,
Just now, REX8836 said:
i7-8700k
well bloody hell, any of those GPUs will easily play PUBG at 100 fps
Well, any of those are more than capable of playing PUBG, but what are his other components because the GPU determines the quality it can run at, but the CPU determines the fps
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/971046-gpu-help/#findComment-11744291
i7-8700k
https://linustechtips.com/topic/971046-gpu-help/#findComment-11744301
