Hey guys, I am new to the PC master race and would like some help with knowing what would need to be upgraded, I know my PC is not that old but I was wondering if I need to upgrade my mother board in order to get a new processor maybe because the chip set is not compatible (will have full list of PC parts below), help on this subject is greatly appreciated.
ASUS Z170-AR LGA1151 Socket
Intel i5 6600K
16GB Ram (dont remember which model)
GTX1070 Strix
I think I have a 750W power supply
Corsair water cooling
Thanks guys hope you can help me
https://linustechtips.com/topic/970311-upgrading-my-pc-need-help/
If you mean "new processor" you mean 8th or 9th gen intel core CPU's then yes, you'll need a new B360 or Z370 motherboard.
Thing is, why do you need to upgrade though? Your system's perfectly fine.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
3 minutes ago, DrShabangbang said:
Thats what I thought, would my cooler fit on that motherboard or would i have to get a new cooler?
They're all socket 1151, should fit.
You may upgrade your PC if you want, but it's not needed anyway. And yes, you'll be needing a new motherboard if you will upgrade.
