Hi all i got a few routing method but idk which one is faster any ideas thanks (i mainly use it for gaming and torrent but my pc its using wireles so speed matters)
Top method
Modem(inside cabinet) --->ethernet router(inside cabinet) --> set my asus ac5300 as wireless ap
Bottom
Modem(inside cabinet) ---data point--->router(in living room)--route back to cabinet--->switch(inside cabinet) ---->to rest of the ports?
----------------------------PC Build--------------------------------
CPU: Ryzen 2700x
M/B: Gigabyte AX370
GPU: Gigabyte G1 Gaming GTX 1080
RAM: KLEVV CRAS II RGB 16GB 3200Mhz
Case: Fractal Design Meshify C Blackout
Storage: Samsung 860 evo 256GB & WD Blue 1TB
PSU: EVGA 750W Gold+
Aiming to get Secret Lab Omega
https://linustechtips.com/topic/970010-ideas-for-routing/
It isn't routing that is going to be a problem, you know everyone is going to recommend the bottom method (where your computers are hard wired in) because it's always going to be the more reliable method. You mentioned that your computer is wireless, you're not really going to be running into any speed issues without first changing from wireless to wired, I wouldn't be worried about your method of connecting devices unless there was a specific device that bottlenecked such as the wireless card in your actual PC, or the signal/strength between your pc and the ac5300. or even running bad cable between your router and switch (or having a 100Mbps switch with internet speed higher than 100Mbps)
I'm going to put a link to my PC specs which actually aren't my PC specs and I cry myself to sleep everyday so I can have these PC specs but I can't afford these PC specs so PC specs PC specs PC specs PC specs PC specs PC specs.
https://linustechtips.com/topic/970010-ideas-for-routing/#findComment-11734898
