Cable connection
Go to solution Solved by crosstiger,
Normally the gpu box only includes molex or sata adapter cables. But there should be no need to use them so stick with the pcie cables which are included with your psu. A single cable with two 8pins is enough.
If you find any grammar or spelling errors please fill out entry permit A38, thanks.
Greetings from germany
Profilepicture by Chibiterasu-chan
https://linustechtips.com/topic/969737-cable-connection/#findComment-11732506
