Do I 100% NEED a case? I am trying to build a pc and save money.. i can save $50 (to get a better gpu or something.. or just save it..) 50$ may not be alot.. but it is still something. I will DEFINITELY get a case for it in the near future (a few months) and I will probably build something (with cardboard, wood, etc) as a placeholder (or i might just put it on a box and point a big fan at it) is a big fan a good idea?
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
https://linustechtips.com/topic/969447-do-i-need-a-case/
I plug everything in empty cardboard box after a coffee machine. It works. But I made it just for fun and using old hardware.
Problem will be with graphics card.
Most important is - if you have no money now, you may spend much more later if (for example) your PCI-E card will pull out your PCI-E connector because poor assembly.
Many people uses desks or walls to build their PC (check youtube), but it's mostly more expansive than just buying pc case.
https://linustechtips.com/topic/969447-do-i-need-a-case/#findComment-11729347
Okay thank you
https://linustechtips.com/topic/969447-do-i-need-a-case/#findComment-11729351
Just now, Rallenhayestime said:
No, a large cardboard box will do just fine... Remind me in 5 hours for an example.
Should i leave one side open and put a box fan facing it for airflow?
https://linustechtips.com/topic/969447-do-i-need-a-case/#findComment-11729353
Just now, Tibon said:
Dont forget to get yourself a jumper switch to act as a temporary power button. Unless your motherboard has an onboard powee button.
I actually will go look at the pictures if i see a power button. I will get back to you in a few minutes
https://linustechtips.com/topic/969447-do-i-need-a-case/#findComment-11729362
No, it does not so i will need to get a switch. Where would i get one?
https://linustechtips.com/topic/969447-do-i-need-a-case/#findComment-11729369
1 minute ago, Rallenhayestime said:
You can just use anything metal to short the power pins
I assume i would just look up how to use a jumper switch on a Micro ATX AM4 motherboard?
https://linustechtips.com/topic/969447-do-i-need-a-case/#findComment-11729378
No, it isn't necessary. Cardboard works well for a test bench. A large fan can help but isn't necessary. The fans from the cpu cooler and graphics card is generally enough.
IMG_20160615_005129.thumb.jpg.19f55f3c64081873eb0bb30c148275fa.jpgIMG_20160529_223005.thumb.jpg.db8a1b411a67b8146e8ba9fa09813924.jpg5b92ac38e4793_IMG_20160529_22292201.thumb.jpg.71401c326cd90b5150bb6df4b01b1d61.jpg
Bridging the power switch pins with a screwdriver or knife works too.
Moved to Cases and Power Supplies.
https://linustechtips.com/topic/969447-do-i-need-a-case/#findComment-11729380
  Hide contents
Okay thank you. I like the look of a pc without a case. It allows tou to see everything spin, if it has lights you see if flicker on and it is so satisfying. I know some cases has clear sides but then i wont see it from all angles. The fact it saves a bit of money is just one benefit. I will probably use a small desktop fan to help cool it anyways. Thanks for the pictures, it helps me understand what it should look like rather than me trying to imagine it. I appreciate it
https://linustechtips.com/topic/969447-do-i-need-a-case/#findComment-11729397
4 minutes ago, homeap5 said:
I have PC case, but I mounted two buttons in my desk and plug into mainboard. Much better that way. :) For lazy people. :)
Why? ;) He don't want a pc case. :)
 Lol i will probably just use a button as well.
Pfft. Then again, we are discussing cases (or rather, the lack of)
https://linustechtips.com/topic/969447-do-i-need-a-case/#findComment-11729403
Just now, wONKEyeYEs said:
Thermaltake P3 eh.
THAT IS UGLYYYY im soo joking. That looks super cool. I forgot those kinds of cases exist lol. I love those kinds of cases. But I dont think I will buy a case like that quite yet. But just in case (no pun intended) what are those called? Just “Glass top case”?
https://linustechtips.com/topic/969447-do-i-need-a-case/#findComment-11729424
Open frame
https://linustechtips.com/topic/969447-do-i-need-a-case/#findComment-11729438
7 minutes ago, wONKEyeYEs said:
Thermaltake P3, eh.
5 minutes ago, WoodenMarker said:
Open frame
Okay awesome. And i thought when you said ThermalTake P3 you were making a reference or something lol idk.
https://linustechtips.com/topic/969447-do-i-need-a-case/#findComment-11729465
1 minute ago, Jtalk4456 said:
if you know your way around tools you can put it in a desk drawer
Image result for drawer pc
Woah woah woah! What about cooling?
https://linustechtips.com/topic/969447-do-i-need-a-case/#findComment-11729487
