Prototype Mobile PC case I made for studies
I posted this topic in cases and PSU's but I thought this would be a better place for the topic (don't blame me i'm new here :rolleyes: )
I designed the case to carry standard ATX size motherboards and PSU's to give the consumer a great Price/performance ratio as these components tend to have better of those. Also this means it is suitable for Socket 2011 boards. That means Professionals can use this as a powerfull mobile workstation. They could install like a powerfull CAD card like a Quadro K6000 along with a 2011 type CPU.
But wait there is more tongue.png with Valve's upcoming steamboxes this could be a very good candidate. Because like previously stated the ATX form factor gives a great price to performance ratio. This is very important to nearly every gamer, especially the ones coming from the consoles ( as they tend to spend less on the initial system). You could carry your steambox around to lets say your friends house because of the carry handle.
I designed the case so that the PSU airflow is seperated from the rest. On the back of the case their is a dedicated intake for the PSU. The front of the case is also free of messy cables obstructing airflow because of the slot cut out to channel them through the back into and arrea that doesn't need much airflow. Because the graphics card is tilted 90 degrees it can suck air almost directly from outside the case, eliminating the problems of rest heat coming from other components. A nice added benefit is that you can now see the gorgeous cooler design of your GPU instead of looking at the side and top. From an esthetical standpoint I think that is great because you spend a lot of money on your GPU and now you have added value of actually seeing the design
I am looking for feedback from you guys. If you have recommendations please I'd love to hear them.
Also I still need a name for it
System Specs:
4670K
8GB 1600 RAM
660TI 2GB
600 Watt PSU
Samsung 128 GB 840 PRO
support-34847-0-18894900-1388703136_thum
support-34847-0-52936000-1388703138_thum
support-34847-0-15092100-1388703150_thum
support-34847-0-85569600-1388703161_thum
support-34847-0-29698000-1388703172_thum
support-34847-0-28095100-1388703103_thum
support-34847-0-19061000-1388703122_thum
support-34847-0-13843900-1388703113_thum
https://linustechtips.com/topic/96860-prototype-mobile-pc-case-i-made-for-studies/
Aw man don't double post! :P
But looks good!
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
Holy shit, that is awesome!
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
Excellent design! Are there any cable routing holes?
Yes, there is a slot cut out running from the top al the way under the GPU. Additional cabel routing holes might be added. But right now with this hardware I don't see the need
dude, can i make 3d model? or can i have one copy so that i can make a metal/aluminium version? i need your permission first.
i dont trust wood(mdf), they are cutting a lot of trees for mdf. but mdf is great for ease of modelling.
For non commercial purposes everyone is free to create what they want. As long as you do not claim the design as your own. I do not want to release my 3d models yet.
Edit: I think MDF is made from waste wood chips so I don't think I've hurt too many of my tree friends
Wow that's awesome  :D
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
Oh that is nice, and unique! Loveing the custom case design and sideways mounted gpu!!
Build log
CPU: FX-6100 @ 3.9 MOBO: GA 990XA-UD3 RAM: Corsair Vengeance 8GB GPU: HD6870 PSU: Corsair GS800 Case: Bitfenix Outlaw SSD: Samsung 840 250GB HDD: Seagate Barracuda 1TB Cooling: Custom Water-Cooling Peripherals: Keyboard: G710+ Mouse: Steelseries Sensei Steering Wheel: Logitech G27 Sound: Speakers: Logitech x530 Headset: Razer Chimaera Monitor: Benq G2450HM, LG 32" TV
