Where do i connect?
Solved by daimonie,
20 hours ago, CatCam1 said:3rd from the bottom
Right. As far as I know (and the manual of the AIO should specify), the 4 pin connectors are not usually very fancy. The CPU Fan header should do.The following image comes straight out of an AIO manual: https://www.corsair.com/uk/en/Categories/Products/Liquid-Cooling/Dual-Radiator-Liquid-Coolers/Hydro-Series™-H100i-Extreme-Performance-CPU-Cooler/p/CW-9060009-WW
"Connect pump power header to PSU and 3-pin pump RPM wire to any motherboard 3 or 4-pin header."
