Reset it to factory default
https://linustechtips.com/topic/968391-no-sound/#findComment-11719166
19 minutes ago, GAMINGGUY said:
I was messing around with my monitor settings (LG 34UM69G-B) And somehow I disabled the audio. Everything is turned on and up. And also my youtube is lagging now???????????????? CONFUSED MUCH?
just please help.
are you running audio through HDMI or PC speakers?
if at first you don't break it you must have followed the directions
https://linustechtips.com/topic/968391-no-sound/#findComment-11719189
