To start off, I apologize if this is either a stupid question or in the wrong category. I was just wondering if when changing my processor, all I have to do is remove my cooler, take out the CPU and then reapply paste and the cooler. Or if there is anything else that I might need to do. Thanks
https://linustechtips.com/topic/96816-cpu-change-help/
Make sure to clean the past before reapplying it. No need to remove your cpu. That's about it.
https://linustechtips.com/topic/96816-cpu-change-help/#findComment-1295278
You'll need to clean off the thermal paste left on the cpu from the old cooler, just put some isopropyl alcohol on a microfibre cloth and rub the surface of the CPU.
Build 1: 4770k (H100i) | 2 x MSI 280X Gaming 3G | Asus ROG Maximus VI Hero | Corsair RM850 | 16GB Corsiar Vengeance 1600MHz | Corsair Obsidian 750D |
Build 2: 3770k (Titan Fenrir Evo) | Powercool 3GB HD7970 Asus Sabertooth Z77 | Corsair TX750 | 16GB Kingston HyperX Genesis 2133MHz Inwin Fanqua |
https://linustechtips.com/topic/96816-cpu-change-help/#findComment-1295289
Sorry if I was unclear, I meant changing the CPU.
Oh my mistake. In that case, it sounds about right. Just make sure to clean off the old paste.
https://linustechtips.com/topic/96816-cpu-change-help/#findComment-1295342
How do I clear CMOS?
If there is a button labeled CMOS on your motherboard use that, if not you can take out the mobo battery for 10s and put it back again.
This and remeber to switch PSU off while doing so. And if you can't find Clear CMOS button, check on mobos manual.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/96816-cpu-change-help/#findComment-1304398
