My current setup specs are following:
CPU: Intel Core i7 4770k @ 4.6GHz 1.28V - Delidded
GPU: iChill X4 Nvidia GeForce GTX 1070
CPU Cooler: Noctua NH-D15
Motherboard: Gigabyte Z87X-UD3H
RAM: 16GB HyperX Fury 1866MHz
Case: Fractal Design Define S
Fans: 6x Fractal Design Dynamic GP-14
PSU: Corsair RM550x Fully Modular
SSD: Samsung 860 EVO 500GB & Samsung 840 EVO 120GB
HDD: Seagate Barracuda 1TB
Screens: Dell S2417DG (1440p, 165HZ, G-SYNC) + LG 22EA63 (1080p 60Hz IPS)
Keyboard: Logitech G810
Mouse: Logitech G403
Speakers: Logitech Z333
Headset: HyperX Cloud II
Webcam: Logitech C920
Microphone: Blue Yeti
https://pcpartpicker.com/b/kKq48d
I was wondering how should I continue with this build, what are your suggestions? Is whole platform change neccessary (Intel 9th gen + Mobo + RAM). Should I just get an GTX 1080Ti or RTX 2080 (whatever the benchmarks closest one is) expecting 4770k can keep up with it? Can the PSU even hold up with an 1080Ti for example?
Things that I'm mostly sure I'll do eventually with the build:
- Change that 1080p panel with simmilar, same sized Dell 1440p 60Hz panel
Feel free to share your thoughts!
https://linustechtips.com/topic/968024-help-me-with-future-build-plans/
6 minutes ago, Yoola said:
Buy a used 1080ti for like $500 soon ish if you want more GPU performnace
PSU is fine for it if you don't do heavy overclocking and then run furmark.
CPU is probably fine for another few years unless you just want more cores on the cheap with Ryzen. The i7 2600K is still mostly fine.
I would start by upgrading the graphics card as your current CPU should be able to keep up with 20 series in games and similar apps. Maybe also upgrade to 32GB of ram as some games are demanding more than 16gb of ram at high res+framerates (but don't make this a priority).
The 20 series appears to be a joke and a waste of money if it's only a 20-30% performance bump at $1199 vs the 1080ti.
It might be too soon to tell how much of this is driver related as historically older cards with more refined drivers have seemed to keep up with new counterparts at first only to be left in the dust in a few months.
That was one of the very likely scenarios
Never so far got to max out 16GB :'D
8 minutes ago, doomsriker said:
Gasp :o
What? :o
After Fermi Nvidia made drivers auto throttle card when detecting Furmark and games can reach completely same power draw level.
AMD cards behave also in same way.
With current prices inflated by cartel of DRAM makers no sense in that.
And resolution affects to GPU memory usage, not CPU memory usage.
Again higher frame rate doesn't increase memory usage, because GPU doesn't store any more frames in its memory.
(and neither has game engine any use for storing game state for more frames)
