Hello folks,
Before i start with the problem, i mention to you my pc components :
CPU:FX-8320 stock
PSU:Corsair CX 600
MOBO:990 fxa ud3 rev2
HDD:1tb WD caviar blue
SSD:Samsung 840 128gb
GPU:GTX 780 Gigabyte OCed edition 3gb
RAM:2x4GB 1600 mhz ddr3
I was playing csgo and suddenly my screen froze.I had to "kill" it :( .
When i restarted it my card's drivers were missing and i faced those errors. (pictures below).
Furthermore i should inform you that electricity runs through my card (card's fans working)
Things i've tried :
1)Clean unistall/install drivers
2)Clear CMOS
3)Bios update
4)Format (repeating the steps above)
5)Replace GTX 780 with GTX 650 ti boost 2gb (stock). ****
****When i replaced GPU and installed its drivers everything seemed to be working properly.
I'm ready to EAT myself please bring light to this case !
Thanks in advance,
May the G-FORCE be with YOU
https://linustechtips.com/topic/967624-problem-with-gpu/
I don't know if it does thin in the 780 but GPU's tend to turn the fans off after booting for silence
If ur playing a game and it still not spinning or won't even boot well u need to find a new gpu
ASTRAY NOIR
CPU
Ryzen 5 3600
Cooler
Corsair H100I PRO
RAM
PNY XLR-8 EPIC-X DDR4-3200 CL16 32GB
GPU
ASUS ROG RTX 2070
STORAGE
SAMSUNG 850 EVO, 2xSEAGATE BARRACUDA PRO 1TB,A2000 1TB
Case
NZXT H500
PSU
Enermax Revolution DF 650W
MONITOR
MSI MAG272,LG 22MP68BQ,DELL D2015H
PERIPHIRALS
Ducky One 2 (HORIZON) || Glorious Model O- Pink || G305 || Razer Nari Essential || HyperX Cloud II
https://linustechtips.com/topic/967624-problem-with-gpu/#findComment-11711778
hardware problem with the GPU id guess, you can check for bloated/blown caps or any burn marks but thats about it. card is probably dead
Builds:
https://linustechtips.com/topic/967624-problem-with-gpu/#findComment-11711791
