Monitor mount
Solved by BoggerBoss,
1 hour ago, Jonas_2909 said:So I guess an arm like this would be ok, but might be too short, right?: https://smile.amazon.de/Bestand-Aluminium-Tischhalterung-Schwenkbare-Neigbare-Single-arm-Table-Grau/dp/B01MF8A0OB/ref=sr_1_9?ie=UTF8&qid=1535899667&sr=8-9&keywords=Monitorarm
i ended up finding some up to almost 2 meters long. although expensive but i dont mind too much as it wont be a main focus item for my set up. thanks alot. https://www.ergodirect.com/default.php?cPath=795
