4770 is rocking some serious value right now, depending on if you already have a haswell motherboard, and if you want unlocked awesomeness, the 4790k is compelling as hell. It utterly rocks. Haswell has lots of life left in it, so you're gonna like whatever it is you get. Just make sure you've got the clock speed to make the magic happen though, because I could never recommend an i5 4430 or something.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/967063-haswell-system/#findComment-11707039
thats the exact cpu i have a i5 4430 with a x series mother board so what cooler for the i7 4790k if i wanted say around 5ghz?
https://linustechtips.com/topic/967063-haswell-system/#findComment-11707454
Doubt you’ll be hitting 5hz regardless of the cooler. If it could, it wouldn’t hold temp wise for a sustained load.
Maybe some non cpu intensive games.
360 aio at least with no delid.
https://linustechtips.com/topic/967063-haswell-system/#findComment-11707485
Expect 4.6 or 4.7 All cores. Still kicks ass at that speed. I recommend a nice large air cooler for ease of maintenance.
Primary PC:
PSU tier list
https://linustechtips.com/topic/967063-haswell-system/#findComment-11707535
what could i expect with a decent air cooler
https://linustechtips.com/topic/967063-haswell-system/#findComment-11712214
