Hello my Name is Chris and i have built multiple PC's in the past and my current build has been working fine for the past two years with no issues. Just recently the slightest bump to the front of the case will cause the computer to freeze and it has to be restarted in order for it to work properly again. I was thinking it was being caused by my drives since they are in the front of the case. Has anyone else run into this issue or have advice for how i should fix this?
PC Specs:
ASUS CrossHair V fromula Z
AMD 9370fx Eight core 4.42GHZ
G-Skill DDr3 16gbs
WD Black performace drive
Samsung 850evo 500gbs
EVGA 980 TI
https://linustechtips.com/topic/966950-help/
There's probably a loose connection or a bad contact, try reseating all the cables in the system
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/966950-help/#findComment-11705965
Do as @Djole123 mentioned above.
If problem still persists try installing Windows on the SSD and see if it's still there.
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/966950-help/#findComment-11705979
