Hey guys does it matter were i plug in my cpu connector and graphic card connector on the "be quiet! Straight Power 11 CM 750W" As the lables on the psu just says PCIE1 , PICE2 etc So i know on the cpu im using a 8 pin one ( it says on the cable ( cpu1-p4 and cpu2-p8)) and then for the grahic card one im using the (6 pin to 16 pin connector for the graphic card ) and thats labled vga1
Any help would be great :)
My parts: https://pcpartpicker.com/list/xBwBzY
Ive added a pic to show the psu
https://linustechtips.com/topic/966912-power-supply-plugin/
Plug it into the 8-pin connector directly next to the 24-pin. (The one closest to the warranty void if removed sticker)
https://linustechtips.com/topic/966912-power-supply-plugin/#findComment-11705584
6 minutes ago, Blindeagle said:
I plugged the 24 pin one into there, do you mean the one above it?
Hmm... Didn't realize the one I saw floating around the picture was just for the 24-pin.
I'd check the manual, it should know where to put it.
https://linustechtips.com/topic/966912-power-supply-plugin/#findComment-11705644
