Thinkstation S20 USB Boot Problem
Solved by GodOfKnockers,
Update: never mind guys. I Updated the BIOS and learned that this model does NOT have UFEI. I also learned that you have to insert the flash drive a few moments into starting up the PC. It will NOT work if you insert it before turning the PC on.
Issac Zachary ·
Posted in Troubleshooting1 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
play_circle_filled
Latest From ShortCircuit:
