Hey everyone,
so ive been using pcpartpicker to try and plan my first build. Its going to be primarily a gaming rig, but also used for some uni stuff. Im trying to keep it as close to $2500 AUD as possible and im pretty happy with what ive got, but seeing as this will be my first build i was hoping some people could double check that all these parts would suit each other or if you guys have any suggestions/replacement parts. Ive made the list here https://au.pcpartpicker.com/list/hpdP8Y. Id especially love some suggestions on motherboards and powersupplies as ive got no idea about that stuff.
https://linustechtips.com/topic/966358-first-build-need-tipscomponent-check/
the G3 has issues with protections, look for an RMx, TXM or G2 instead.
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($518.00 @ Shopping Express)
CPU Cooler: Scythe - SCNJ-4000 84.6 CFM CPU Cooler  ($66.89 @ Amazon Australia)
Motherboard: ASRock - Fatal1ty Z370 Gaming K6 ATX LGA1151 Motherboard  ($228.00 @ Umart)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($239.00 @ Shopping Express)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive  ($132.00 @ IJK)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($77.00 @ Shopping Express)
Video Card: Zotac - GeForce GTX 1080 Ti 11GB Mini Video Card  ($986.26 @ Amazon Australia)
Case: Corsair - Carbide Series 275R (White w/Tempered Glass) ATX Mid Tower Case  ($98.90 @ Shopping Express)
Power Supply: EVGA - SuperNOVA G2 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($146.00 @ IJK)
Total: $2492.05
Generated by PCPartPicker 2018-08-30 12:16 AEST+1000
If the plan is to overclock, get a better cpu cooler. Otherwise, get an i7-8700 and an H370 motherboard.
As others have suggested, the G3 has some issues. The 650W G2 would be a very good choice.
CPU Cooler: Cooler Master - MasterLiquid ML240L RGB 66.7 CFM Liquid CPU Cooler  ($88.00 @ Centre Com)
Motherboard: MSI - Z370M MORTAR Micro ATX LGA1151 Motherboard  ($159.00 @ Shopping Express)
Memory: G.Skill - Flare X 16GB (2 x 8GB) DDR4-2400 Memory  ($209.00 @ IJK)
Video Card: Zotac - GeForce GTX 1080 Ti 11GB AMP Edition Video Card  ($1079.00 @ Scorptec)
Case: Thermaltake - Versa H18 MicroATX Mini Tower Case  ($49.00 @ BudgetPC)
Power Supply: Corsair - TXM Gold 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($129.00 @ Shopping Express)
Total: $2440.00
Generated by PCPartPicker 2018-08-30 18:55 AEST+1000
