Hi,
 I live in the UK and I am looking to build myself a computer in September for the purpose of both high end gaming and completing CAD work set by my university (Avionics Systems is the course I am doing if anyone is wondering. :-)
An example of software and games that i will use:
* SolidWorks
* Creo
* X-plane 11
* GTA V
* CS GO
* LoL
Here are some criteria:
1. Must have Ryzen 2700X, equivalent or better.
2. 32GB of RAM would be preferable.
3. M.2 SSD would be very nice for the programs.
4. HDD for mass storage.
5. I would like to overclock CPU.
6. Aesthetics are not required but if the budget allows can be used.
7. WiFi adaptor is a must (no way of getting a LAN cable to my room without demolishing the piping in the floor)
8. No OS required
9. Already have the peripherals
10.Expandable
Go wild :D
Thanks!
https://linustechtips.com/topic/966243-need-help/
1 hour ago, StrangeGamer said:
Hi,
* SolidWorks
* Creo
* X-plane 11
* GTA V
* CS GO
* LoL
8. No OS required
10.Expandable
Go wild :D
Thanks!
Budget? Also you pretty much have the pc planned already.
CPU: AMD Ryzen 5 5600X | MOBO: MSI B450 Tomahawk GPU: AMD Radeon RX 6800XT | RAM: GSkill Trident Z DDR4 3600Mhz | PSU: ADATA Core Reactor 850W 80+ Gold | CASE: Fractal Design Meshify C MONITOR: LG 32UL500-W 4K 60Hz, Gigabyte M27Q 1440p 165Hz
https://linustechtips.com/topic/966243-need-help/#findComment-11699410
Hi,
* SolidWorks
* Creo
* X-plane 11
* GTA V
* CS GO
* LoL
8. No OS required
10.Expandable
Go wild :D
Thanks!
Since I don't really know the budget,
Here's an AMD build:
CPU: AMD - Threadripper 1920X 3.5GHz 12-Core Processor  (£348.98 @ Ebuyer)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  (£97.87 @ Amazon UK)
Motherboard: ASRock - X399M Taichi Micro ATX TR4 Motherboard  (£314.40 @ Alza)
Memory: Corsair - Vengeance LPX 32GB (2 x 16GB) DDR4-2666 Memory  (£270.99 @ Ebuyer)
Storage: Samsung - 970 Evo 500GB M.2-2280 Solid State Drive  (£148.79 @ Aria PC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£47.94 @ Aria PC)
Video Card: Gigabyte - GeForce GTX 1080 8GB WINDFORCE OC 8G Video Card  (£444.99 @ Ebuyer)
Case: Fractal Design - Meshify C Dark TG ATX Mid Tower Case  (£79.99 @ Amazon UK)
Power Supply: Corsair - RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£87.99 @ Amazon UK)
Wireless Network Adapter: Asus - PCE-AC51 PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  (£27.95 @ Amazon UK)
Total: £1869.89
Generated by PCPartPicker 2018-08-29 22:08 BST+0100
Although for this one, I would recommend Intel. But you mentioned you wanted something better than AMD Ryzen 7 2700X, which is only Threadripper.
https://linustechtips.com/topic/966243-need-help/#findComment-11699425
Total: £1869.89
I would switch the CPU cooler to H150Proi or better though.
https://linustechtips.com/topic/966243-need-help/#findComment-11699448
