What is Cryix?
Go to solution Solved by kingmustard,
6 minutes ago, Annual Toe said:
I was looking through my stash of old tech from the 90s, and saw a processor with the brand name Cryix. I looked up the name but was met with a wow character. Does anyone know what it is?
will help: https://en.wikipedia.org/wiki/Cyrix
https://linustechtips.com/topic/966111-what-is-cryix/#findComment-11697878
Cyrix. They made x86 processors to compete with Intel and AMD. They were bought out by VIA in the early 2000's.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/966111-what-is-cryix/#findComment-11697887
https://linustechtips.com/topic/966111-what-is-cryix/#findComment-11697891
