Since I am STILL fairly new to this whole thing, I just wanna clarify on this.
The GPU I am looking at has maximum supported resolution of 7680x4320@60Hz (1060 6GB). This totals to 1 990 656 000 pixels per second.
If I plan to use it with 4k TV at 60 Hz (so 497 664 000 pps) and gaming monitor at 1444p144hz (thus 526 694 400), that totals out at 1 024 358 400 which is slightly over half but still not nearly as much as supposed maximum resolution of the GPU.
Does that mean I can use both at their fullest at the same time with such a GPU or it is just plainly wrong to count it like this and if it is, how is the proper way to calculate if I can or cannot use both at the same time at the maximum?
Thank you.
CPU: Ryzen 7800X3D; CPU Cooler: Noctua U12A chromax + NA-HC8 chromax; MOBO: Gigabyte B850M Aorus Elite Wifi6e; CASE: A3-Matx Lian Li Dan Case Wood/Mesh edition; PSU: SF1000 (2024); RAM: 2x16 GB DDR5 Kingston Fury Beast 6000/30cl Expo kit; SSD#1: 1 TB 9100 PRO; SSD#2: 2TB 990 PRO; GPU: RTX 5080 Asus x Noctua; Case fans: 1x A12x25 G1, 2x A14x25 G2 chromax; OS: Win 11 Pro
https://linustechtips.com/topic/965486-maximum-resolution/
Yes, you can use both.
Maximum Digital Resolution refers the largest supported resolution for one display. You can see two 8K monitors running off of a GV100 which has the same 7680x4320@60Hz spec:
https://linustechtips.com/topic/965486-maximum-resolution/#findComment-11692201
