So from what I understand the G-sync Model laptops have g-syn as an option with 1070's and above but the description on this laptop says it has g-sync on a 1060 but with 3gb of vram when the same model number from a different seller has essentially the same specs but with 6gb of vram and no mention of g-syn from what i can see. I was looking for a laptop with at least a 1050ti preferably with g-sync at 15.6 in i had some help on this forum searching so im narrowing it down between these choices. But there is a refurbished version of an older model for around the same price if you believe this third choice is the better deal. Regardless I would still like to know about the description accuracy between the first two models and if i should just give up and go for the third option thank you in advance.
https://linustechtips.com/topic/965200-help-with-description-accuracy/
G-sync isn't the most important feature, but it's useful. I was looking at those laptops and it's a mix of with/without gsync. All mobile 10 series cards support g-sync so if you have a g-sync display then no problem! So it looks like the first laptop has it. My personal advice is to prioritize raw specs before focusing on g-sync compatible displays, with those cards a 120/144hz display should be fine
####################  CPU: AMD Ryzen 5 2500U
####################  GPU: Radeon Vega 8
####################  Ram: 8gb DDR4 2666MHz
####################  SSD: OEM 128gb M SATA
####################  HDD: Seagate Baracuda 1tb 5400RPM
Before answering your question: DON'T buy Asus GL series with KBL-H CPU. They run hot
And yes, different models have different specs
Where are you from? Budget? Usage? Preferred max weight and battery life? Any special requirements?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
G Sync was essentially the final feature i would like to have i played on my previous laptop without it and i just dealt with it but it did have a 960m so nothing to be excited about. I Currently play on a g-sync display the pg279q so i would like to keep g-sync on the laptop as well this time budget was 1300 and i was more confused as to why the 3gb vram option had g sync while the six didnt.  I found a video this morning stating that the 3gb version did indeed have g-sync so i will likely be going for that model and as far as temperatures go it's a laptop so i know high temps in demanding titles are expected. I think at 1300 i probably wont get anything crazy above the specs than i chose already but if you have a better option i would like to hear it the titles that are the most demanding i would think of would be Metal Gear 5, and Black desert Online, anything else isnt as demanding as these two.  Again its a laptop so I understand why it would have 2~hour battery life its not a big deal. 5ish Pounds seems fine and as far as special requirements go again g-sync was definitely preferred  and at least a 1050ti as far as the gpu goes so In my opinion the 1060 3gb vram with g-sync should be enough. I would likely be playing at slightly under 1080p or 720p since it is a smaller screen so i can get away with some higher detail settings here and there. thanks for the responses guys :)
Could you list out all 1050TI and 1060 laptops that are within your budget? (Preferably CFL-H)
Desktop specs:
Hi sorry for an extremely delayed reply, I did some digging around and this is what I was able to find.   Asus GL503VM and the Asus GU501GM. The second one being the one with the coffee lake processor. I dont believe I need anything more than the 7700HQ at least on a laptop even if the 8750 is on par with a 6700k from what ive seen with benchmarks. I am leaning towards the GL503 as it seems to fit what i need best unless there is a huge flaw i am missing. the other one lacks g-sync but still within budget but again i dont believe i would even use the full potential of the 7700hq.
Wait so I'm trying to understand what the hell fast sync is and from what i understand its g-sync/free sync when in action not in exactly the same way  but a slightly higher delay? and works with newer nvidia gpu's
Why only Asus laptops? 7th gen GL series has cooling issue
Desktop specs:
It’s just what I saw that had the specs in my price range and I just figured all laptops overheat at loads because I mean it’s a laptop
Misconception
Desktop specs:
On 03/09/2018 at 5:54 AM, Ramontes said:
So it’s  just the 7th gen processor that’s messed up all around then?
Asus bad cooling design
Desktop specs:
