hi guys im just wondering is this a good wifi card that i can use for my pc
TP-LINK TL-WN881ND
or can u recomond a good for online games download and watching streams oh and my budget $20-$50
amd fx 6300  @4.4ghz @1.4/ga-970a-ud3/HD78702gb /antec 620w psu
https://linustechtips.com/topic/96460-wireless-wifi-card/
TP-LINK TL-WN881ND
Yep, looks good to me.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/96460-wireless-wifi-card/#findComment-1290787
It's good if you're using it for windows,otherwise a chip from qualcomm atheros would be better.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/96460-wireless-wifi-card/#findComment-1290819
