Fan Cooling
Go to solution Solved by WoodenMarker,
Maintaining positive airflow is just a matter of running your intakes at higher rpm than your exhausts.
Moved to Air Cooling. The Troubleshooting subforum is for when you're not sure what's causing a problem.
So this is going to be like just a real on point question and requires no need to know the parts other than the case i think xD
So my case has 4 air filters (one at the top, two at the front and one at the bottom(PSU)). I have the top fan and the 2 front fans sucking the air in while the one at the back is making the air go out not counting the gpu and cpu fans. Do you guys think this is good enough for a positive pressure?
https://linustechtips.com/topic/964413-fan-cooling/
https://linustechtips.com/topic/964413-fan-cooling/#findComment-11683109
4 minutes ago, Taheru said:
I have probably around 1200+ RPM for intake while only ~500 RPM for exhaust would this cause any problems at all? 1 of the fan splitter have the exhaust and the intake so it is just an estimate.
That should work fine. You can use incense for a smoke test and adjust rpm to be sure.
https://linustechtips.com/topic/964413-fan-cooling/#findComment-11683163
