Recently I upgraded my iphone 5s to a Samsung galaxy s9. Since I upgraded they have the same number but somehow I can't receive texts on my new phone. I can text and call from it but once someone tries to call or text me, it goes to my 5s. (I also switched carriers) How do i fix this so I don't have to carry 2 phones?
https://linustechtips.com/topic/963929-phone-issues/
You sure they're text messages and not iMessage?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/963929-phone-issues/#findComment-11678835
I text them from my s9 on the messenger then when they text me back from that message it goes to my 5s. I use verizon. Should I use their messenger instead of the samsung one?
The thing is that they might still be using iMessage rather than sending them as actual text messages. On your 5S, is the messages still appearing in a blue bubble. If so, they're still on iMessage. If it's a green bubble, then it's a text message.
https://linustechtips.com/topic/963929-phone-issues/#findComment-11678856
Are the messages you recieve on the 5S green or blue?
https://linustechtips.com/topic/963929-phone-issues/#findComment-11678857
On my 5s i can't see my messages from my s9.
https://linustechtips.com/topic/963929-phone-issues/#findComment-11678860
10 minutes ago, SHG_Marsh said:
The messages I receive from my friends on iphone are grey and the ones I receive from friends on android are green. But the messages don't go to my s9
Ah right, that's only on your side. This might help you. I still suspect that your friends are still sending message to you via iMessage rather than SMS.
https://support.apple.com/en-ca/HT203042
https://linustechtips.com/topic/963929-phone-issues/#findComment-11678909
