Hey guys,
So I've been having some issues with my HTPC lately. It started with the computer randomly freezing up and being generally glitchy, this was going on for a little under a week. And today it had locked with audio skips and of the media I was playing. When this happened I turned the pc off with the PSU switch and left it for a few hours, then came back later and power drained fully and reconnected the PC. Now it's loading the Bios "enter f12" screen and does not take any input but after a few minutes loads the bios settings menu. If you reset from bios it does the same. The only thing that had been done with the PC before this was using it as a test pc with ram and gpu from a broken pc for diagnosing what was broken.
Specs are R7 1600x
8gb corsair vengeance lpx
Gigabyte AB350N Gaming WiFi mini it mobo
Be Quiet CPU Cooler
Thermaltake Smart 650w 80plus Bronze PSU
MSi GTX 750Ti
Boot drive is a 120gb ssd
Gaming Rig: 1st gen i7 to 8th gen i7 (Build Log)
Specs: i7 8700k : Corsair H110i w 2x Corsair LL140mm RGB Fans : 32GB Corsair Vengeance RGB Pro 3600Mhz : Asus ROG Maximux X Hero AC : EVGA RTX 3080Ti FTW3 Ultra : Phanteks Enthoo 719 w/LL120mm RGB fan : Corsair HX750Sabrent Rocket Q 2TB Boot Drive : WD Black HDD Game Drive : Corsair Lighting Node Pro
Server:
Specs: HP DL380e G8 : 2x Intel Xeon E5 2470 : 48GB Ram : 6x HPE 4TB 3.5" HDDs, 2x 4TB WD Red, 3x WD Red 3TB HDDs, 1x Samsung 850 Evo 250GB SSD : Redundant 750w 80+ Gold PSUs
https://linustechtips.com/topic/963534-ryzen-5-htpc-issues/
Also, Cpu and gpu are not overheating, in a larger case with lots of airflow
Server:
https://linustechtips.com/topic/963534-ryzen-5-htpc-issues/#findComment-11674920
Last time I checks they were 50 idle and 70 to 80 under synthetic load on Cpu. Can't remember gpu but it's not overheating either. Computer is fine temp wise, it's a good cooler on the CPU and gpu and it's in a larger HTPC case,  it's not stuffed in a cabinet or anything like that either.
Server:
https://linustechtips.com/topic/963534-ryzen-5-htpc-issues/#findComment-11674976
I've been having problems where I've had to do this. Its been a constant plague. Check your event viewer and look for Kernel Power 41, if that's the cause its most likely due to Windows power settings. I cannot get Windows to take a new default plan, which means I get nearly 4 random shutdowns a day.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/963534-ryzen-5-htpc-issues/#findComment-11675527
I would if I could get past the Bios. It stops there and cant go any further
Server:
https://linustechtips.com/topic/963534-ryzen-5-htpc-issues/#findComment-11676198
