Metro: LL quality settings
By
cjeffcoatjr
in PC Gaming
in PC Gaming
Solved by Jogostar,
What settings did you play it at? A 660Ti is comparable to a 7870.
I ended up setting most thing to medium/normal, so that I can get a 60 fps.
Like this:
Resolution 1080p
quality-high
ssaa-on
af-16x
motion blur off
tesselation-normal.
vsync-off.
Advanced Physx-off
was at 60 fps constantly
On all maxed I had 45-50 fps
rohleder00 ·
Posted in CPUs, Motherboards, and Memory8 -
Old_Liver ·
Posted in Laptops and Pre-Built Systems0 -
2
2
ghifrank ·
Posted in Troubleshooting2 -
1
1
V_1313 ·
Posted in Troubleshooting4 -
IR76 ·
Posted in Programs, Apps and Websites10
