Hello everyone, so i got an dell inspiron with the gtx1050ti version and i7 7700hq and i lowered cpu state to 80% and undervolted my cpu with -120mv so idk if is it safe to do them both now max temps are 73-74 for cpu or maybe should i put the cpu state to 100% and undervolt to -140 maybe it will work and wont crash with 100% ?? Thanks
https://linustechtips.com/topic/963033-undervolting-cpu-state-maximum-help/
why touch the CPU-state in the first place? Should have left that alone.
Desktop benching:
4 hours ago, elfalloo said:
I saw it on a forum to get cpu much cooler
because the CPU does less work, that's why it will run cooler. The point of undervolting is reducing heat output and power draw without slowing it down.
Desktop benching:
yep ok so what should i do? put the cpu state back to 100%? i will get more like 6-7 degrees on cpu temp ,my question is simple is it doing undervolting+lowering cpu state safe that all
put CPU-state back to 100%, or else you're losing performance. Try undervolt more, though you might crash at the current settings.
Pascal GPUs can undervolt as well, will give a tiny improvement in CPU temps since they share the same cooling system.
Desktop benching:
undervolt more like -140? in the first time with 80 c-state at -140 it crashed ,-130 crashed one time after 8hof watch dogs 2 so ive put 120,and btw THX for help
with CPU-state back to 100%, it should undervolt worse, needing a higher voltage offset to work. That's what I meant.
Desktop benching:
i've put it to 100% right and it didnt crash for -150 -140 which crashed on 80% so idk... -155 crashed i think i will test -145 a little bit
So now with 100% at cpu state -125 on undervolt and cooler pad i get to max 91 degree on watch dogs 2 and 85 on farcry 4 by pytting c state at 99% i get max temp is 85 for watch and 79 for farcry so isnt a little bit too high ?  Btw i bought my pc 2weeks ago..
oh dear, not a good laptop this thing. what model is this?
Desktop benching:
5 minutes ago, elfalloo said:
Dell inspiron 7567 i7 7700hq gtx 1050ti
thin laptops just dont work very well with hot CPUs like this it seems.
Then other than going for RMA 'because it runs hot', your only option is to go back to dropping CPU-states and performance again. Sad.
Desktop benching:
But 80C isnt safe ?
3 minutes ago, elfalloo said:
But 80C isnt safe ?
it's safe, but on a laptop that means loud fans and potentially hot surfaces to touch.
Desktop benching:
So now ive putted it to 85% not 80% and i downloaded msi after burner ( dont take me for a retard but i think msi afterburner got me a free 3-4 degrees for real)  on watch dogs 2 i didnt lost anything on performance and max temp is 73 avg 69 :D but the question is it sage to put the cstate at 85% + undervolt it ? (thx btw for help)  i appreciacte
sage
safe? Yes
You're probably bottlenecked by the GPU in WD2 anyway
Desktop benching:
2 minutes ago, elfalloo said:
this game is optimized by a 6 years old guy
ya, that rasies both CPU and GPU usage
Desktop benching:
