If it were mine, i'd change the 1060 for one with a better cooler, dual fan or triple, also ATX mobo and mid tower, a card so small may look out of place.
Hyper 212 could maybe do with an upgrade, 8600k is pretty toasty, it'll work but the cooler the better.
For very little more money a 240/250gb ssd,  adata ultimate is a good option.
https://linustechtips.com/topic/963009-need-help/#findComment-11669733
The problem is I can't really spend more money
https://linustechtips.com/topic/963009-need-help/#findComment-11669737
Could you please change the list for what you think is better and I'm not sure if I will use that monitor so...
https://linustechtips.com/topic/963009-need-help/#findComment-11669741
you've already got the case?
Desktop benching:
https://linustechtips.com/topic/963009-need-help/#findComment-11669860
5 hours ago, LilPonyHunter said:
I don't have anything yet
just asking because there's no price marked for the case, so I dont know your budget. How much is it?
Desktop benching:
https://linustechtips.com/topic/963009-need-help/#findComment-11671222
36 minutes ago, LilPonyHunter said:
It's about 60$
since you said you cant spend more, my recommendation will be try find a cheaper 1060 6gb or RX 580 (4gb or 8gb doesnt matter), and spend extra dollars on the CPU cooler to sth like the Cryorig H5, Scythe Mugen 5 etc.
Desktop benching:
https://linustechtips.com/topic/963009-need-help/#findComment-11672167
The problem is that pc parts are even more expensive in my country and the rx series are minimum 50$ more expensive than a 6gb 1060
https://linustechtips.com/topic/963009-need-help/#findComment-11672464
not buy the case fans then. Just leave the side panel off.
Desktop benching:
https://linustechtips.com/topic/963009-need-help/#findComment-11672725
I really hope youre joking. Leaving the side panel off would just introduce more dust into the system and make it hotter. I realise he is going with the s340 but a better bet would be to get the meshify c or something and just use the stock fans.
https://linustechtips.com/topic/963009-need-help/#findComment-11673607
I'm not joking. Before I get a proper case, I used an battered old case (house movers... at least I took the internals out) with damaged side panels that doesnt fit anymore, so I throw them away. The PSU mount is also damaged so the PSU isnt inside the case at all
It was like that for a whole year, still not much dust and cooling is much better, compared to before the case was damaged (this case had 1 intake fan in the front)
Quote
I hope you realize that this case cost about as much as S340 + case fans combined.
Desktop benching:
https://linustechtips.com/topic/963009-need-help/#findComment-11675266
