I'm building my first setup and wanted to advice and suggestions on how to improve this build and if there will be any horrible bottlenecks or if the GPU/CPU is over/under powered. PSU, OS, HHD and case have been decided as these are being taken out of the current system i own (Bar the case but its small and sexy asf). I currently have a RX 460 GPU and an A10 6800K Processor. so any suggestions on using these in this build (like another RX 460 and not getting the GTX 1070) Thankss!
https://linustechtips.com/topic/962761-first-build-needing-advice-d/
If you are set on the 10 series (rather than the 20 series that just dropped)  Id suggest the used market, as there are likely a crap ton for sale at much less than retail.
Linux Daily Driver:
CPU: R5 2400G
Motherboard: MSI B350M Mortar
RAM: 32GB Corsair Vengeance LPX DDR4
HDD: 1TB POS HDD from an old Dell
SSD: 256GB WD Black NVMe M.2
Case: Phanteks Mini XL DS
PSU: 1200W Corsair HX1200
Gaming Rig:
CPU: i7 6700K @ 4.4GHz
Motherboard: Gigabyte Z270-N Wi-Fi ITX
RAM: 16GB Corsair Vengeance LPX DDR4
GPU: Asus Turbo GTX 1070 @ 2GHz
HDD: 3TB Toshiba something or other
SSD: 512GB WD Black NVMe M.2
Case: Shared with Daily - Phanteks Mini XL DS
PSU: Shared with Daily - 1200W Corsair HX1200
Server
CPU: Ryzen7 1700
Motherboard: MSI X370 SLI Plus
RAM: 8GB Corsair Vengeance LPX DDR4
GPU: Nvidia GT 710
HDD: 1X 10TB Seagate ironwolf NAS Drive.  4X 3TB WD Red NAS Drive.
SSD: Adata 128GB
Case: NZXT Source 210 (white)
PSU: EVGA 650 G2 80Plus Gold
Just now, will79big10 said:
That memory is way too slow for the Ryzen. You need to go with 3000mhz or higher.....I would definitely do 16gb while you are at it.
i have one stick of "ADATA Premier Pro DDR3 1600MHz 8GB Memory Modules (AD3U1600W8G11-R)" should i just get another stick of it or invest in a new set of 16gb sticks?
19 minutes ago, vanillablock said:
What's the budget and what's your monitor resolution/refresh rate?
Lots to fix potentially.
You don't need to buy windows you can install it for free from their media creation tool
I will definitely be looking for any deals on cards, any drawbacks with 2 RX460s or am i going in the wrong direction completely?
the problem with SLI and Crossfire, is that scaling is never 100%.  Best case, you are looking at 90%.  On average?  Somewhere between -10% and 80%.
Some games work really well, other not so much.
So if you know for a fact the games you play will scale well with multiple cards, sure.  but i recommend a much faster single card, than 2 lesser ones.
-------I know SLI/Crossfire looks cooler tho....... i want a second 1070 for looks...... i need money--------
Linux Daily Driver:
CPU: R5 2400G
Gaming Rig:
Server
CPU: Ryzen7 1700
GPU: Nvidia GT 710
SSD: Adata 128GB
1 minute ago, MedievalMatt said:
Just buy a broken 1070 for next to nothing or just a shroud and shove it into the slot
Image result for over the head gif
Plz explain. i dont even know what the differences between cossfire and sli are...
SLI stands for Scalable Link Interface.  Its Nvidias Dual cards working as one solution.
Scalable Link Interface is a brand name for a multi-GPU technology developed by Nvidia for linking two or more video cards together to produce a single output.
Crossfire is the same thing, but thats was AMD calls it instead of SLI.
You sir, are a genius.
Now for a trip to eBay to intentionally buy broken shit from the inter
Linux Daily Driver:
CPU: R5 2400G
Gaming Rig:
Server
CPU: Ryzen7 1700
GPU: Nvidia GT 710
SSD: Adata 128GB
Before anything else what's your budget and monitor resolution/refresh rate?
Most likely just use your RX 460 until the 20 series launches September 20th
SAMSUNG C24F396 Full HD 24" Curved LED Monitor and budget is about £800-900 excluding PSU, HHD and maybe the 460 but that will soon go.
thanks, would i be facing any bottlenecks with a a10 6800k @ 4.3ghz  and rx460, i might just cheap out and get a new cpu (is assume the cpu is the bottleneck) for this build for the next year or so until i have a better budget
Is it 1080p 60hz or 144hz?
Either way just wait for the new GPUs, will be fastest at near the same price points anyways
Get a 240mm AIO at minimum, and a decent unit, not from coolermaster.
Save money on the CPU and get a better motherboard, if not then get an ASrock Pro4 B450 or MSI Tomahawk B450
and yes your CPU is the main bottleneck
PCPartPicker part list: https://uk.pcpartpicker.com/list/zJB8bX
Price breakdown by merchant: https://uk.pcpartpicker.com/list/zJB8bX/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  (£148.79 @ Aria PC)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard  (£129.98 @ Box Limited)
Memory: Patriot - Viper 4 16GB (2 x 8GB) DDR4-3000 Memory  (£137.49 @ Ebuyer)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case  (£43.79 @ Aria PC)
Total: £460.05
Generated by PCPartPicker 2018-08-21 02:48 BST+0100
yea, a CPU would be a good upgrade,  that will be holding you back.
If you want to stick with AMD.  R5 2600, and a 2400g is iGPU is valuable to you.
Linux Daily Driver:
CPU: R5 2400G
Gaming Rig:
Server
CPU: Ryzen7 1700
GPU: Nvidia GT 710
SSD: Adata 128GB
what's your budget? quite a few things i'd change in there.
How about this? This list is including stuff i have already but i think it will leave it open to upgrade to the 20 series when they come out. Case Aesthetics are pretty important to me so yeah. coming in at "£547.68" before the 20 series come out and empty my purse . What performance improvements should i see before upgrading the card? How long will this system be acceptable for?
35 minutes ago, vanillablock said:
The coolermaster AIOs are low quality
That case has no airflow
