Does an overclocked monitor revert on another PC?
Um you don't actually overclock the monitor. You are increasing the hz rate on your computer. This can either cause the monitor to display images at a faster rate increasing refresh rate... or if it isn't up to the task will just cause you to see a black screen because it cannot take the signal.
In some rare cases you can burn out a display, but I haven't see or even heard of that done more than a handful of times over the years.
So to answer your question. It WILL be stock when on another machine, because the method is done on the computer not the monitor. It would probably void your warranty, but this isn't something they can easily track down so unless you call them and say HEY I DID THIS AND IT BROKE! Then chances are your warranty will be unaffected.
