Just got the Asus rog Strix 1060 chucked it into a system that had never had a GPU only igpu and it has never failed me but when I put the card in the system plugged everything in i start the system and after a bit of loading (really low resolution btw) it goes black and after like 30min of waiting for nothing happens so when I boot in safe mode and install the drivers same thing any help also I suck at pc's:(
also using a 6 pin and 2pin instead of 8 pin no power errors tho.
SPECS:
AMD A10-9700 RADEON R7
8gb don't know what speed ram
64-bit os windows 10
igpu ( or you know if i can get it 2 work 1060 :( )
https://linustechtips.com/topic/961635-please-help-me/
you need to run DDU to clean all old drivers. go into BIOS and set it as the active card. and lastly update your mobo drivers if your can.
PSU Tier Ranking List
Ryzen 5 1600x|ASROCK                      |16GB DDR4 3400Mhz Corsair Vengence   | (partial build in progress)
FX-8350 AM3+| ASUS M5A990FX V1 | 32GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H100i v1
FX-8120 AM3+| ASUS M5A990FX V2 | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H80i v1
I5-2500K LGA  | ACER MOBO??         | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 860 PRO | Win 10 64 Pro | EVGA 750W G PSU | EVGA 970 SC 4GB | Corsair H80i v1
https://linustechtips.com/topic/961635-please-help-me/#findComment-11656943
16 minutes ago, craftyisanoob said:
Thanks my motherboard has UEFI and I can't get to bios but will run DDU (EDIT: dosent matter if i was using intergrated graphics before?)
UEFI is your BIOS and no it doesn't matter as ALL display drivers will get removed. just backup or download the iGPU drive b4 u start.
https://linustechtips.com/topic/961635-please-help-me/#findComment-11656984
