Does ram speed really matter... over 3200MHz on 8th gen Intel?
Buying the final components for an 8700K gaming build to replace an older 6700K build and wondering if I should buy 3200MHz RAM or faster?
Watched an older video from April 2017 on the topic of RAM speeds with Intel 7th gen and it showed only marginal improvements in performance after 3200MHz. Testing was done on a 7700K and there hasn’t been an update to this video with an 8700K (or Ryzen for that matter). At least I haven’t seen an update for 2018. Is it worth revisiting this subject? If not what is the consensus for an 8700K... and for other CPUs for that matter as well.
Quote
There he goes. One of God's own prototypes.
A high-powered mutant of some kind never even considered for mass production.
Too weird to live, and too rare to die.
– HST
Coffee Lake's result is about similar to Kaby Lake. High frequency memory helps a tiny bit in average frame rates only, but benefits minimum frame rates quite noticeably if your doing high refresh rate gaming.
The effect on Ryzen is about 3x to 5x greater than that on Kaby Lake.
Desktop benching:
On Ryzen the higher the speeds the better, but for Intel 8th Gen I don't think the gains are worth the price. But I haven't personally tried high refresh rate gaming with RAM speeds that high.
