bad FPs need help
Go to solution Solved by RyzenDoctor,
It was on slow mode. On MSI motherboards it’ll boot with 800mhz, expect sub ambient temps to reach the normal range of temperatures. If the temp is deemed higher than what’s expected on liquid nitrogen it throws a throttling signal at the CPU which prevents it from going beyond 800mhz
So im getting bad fps on overwatch. I have been trying to fix it for awhile now and nothing has been working.
GPU-  NVIDIA GeForce GTX 1070
CPU-  Intel Core i5-7600K LGA 1151 Desktop Processors
CPU Cooler- Cooler Master RR-212L-16PR-R1 Hyper 212 LED CPU Cooler with PWM Fan, Four Direct Contact Heat Pipes
RAM- Ballistix Sport LT 8GB Single
Motherboard- MSI Enthuastic Gaming Intel Z170A LGA 1151 DDR4 USB 3.1 ATX Motherboard
Storage- Seagate 2TB BarraCuda SATA 6 Gb/s 7200 RPM 64MB Cache 3.5 Inch Desktop Hard Drive
https://linustechtips.com/topic/961140-bad-fps-need-help/
Be sure that it not on AUTO just hard 100%
and ofc check if its running on your GTX not integrated
R7 9800X3D, Arctic Liquid Freezer III 360 ARGB, ASRock X870E TAICHI, Kingston FURY 64GB (2x32GB) 6000MT/s CL30 Beast Black RGB , Gigabyte RTX 4090 Gaming OC, Windows 11
https://linustechtips.com/topic/961140-bad-fps-need-help/#findComment-11652652
ofc = of course
Did you try reinstalling drivers and did you check CPU/GPU temps while game is running ofc ?
https://linustechtips.com/topic/961140-bad-fps-need-help/#findComment-11652662
Temp ? is 35% ?
Can you screenshot this for me after running the game ? https://www.cpuid.com/softwares/hwmonitor.html
https://linustechtips.com/topic/961140-bad-fps-need-help/#findComment-11652684
I want screenshot of the HWmonitor app i linked for you especially CPU part cuz i am suspecting it might be overheating just run the app before you start the game.
Something like this:
https://linustechtips.com/topic/961140-bad-fps-need-help/#findComment-11652705
And this is after running OW ? While having HWmon open ? If yes then CPU doesn't speed up for some reason... you could check power options in windows.
https://linustechtips.com/topic/961140-bad-fps-need-help/#findComment-11652732
So yea the problem is CPU is not increasing it colocks it should be running at at least 3,8GHZ but it is running at 800MHZ, check WIndows Power Setting first.
https://linustechtips.com/topic/961140-bad-fps-need-help/#findComment-11652757
Set it to balanced then click on image.png.a7da12a1ea9b3499c75a041738bb6cc0.png ( change plan setting blue text ) and then restore defaults ( blue text ).
https://linustechtips.com/topic/961140-bad-fps-need-help/#findComment-11652782
reset that plan 2 defaults and try running the game if that doesn't help we go for a next step
https://linustechtips.com/topic/961140-bad-fps-need-help/#findComment-11652791
Then lets go for a BIOS update:
This is a BIOS for your mobo: https://msi.com/Motherboard/support/Z170A-GAMING-M5
And this is how 2 install it: https://msi.com/files/pdf/How_to_flash_the_BIOS.pdf
https://linustechtips.com/topic/961140-bad-fps-need-help/#findComment-11652813
You can check in CPU-Z if it updated ( https://www.cpuid.com/softwares/cpu-z.html), and one more thing you can do now is restoring optimized defaults or just default settings in BIOS
https://linustechtips.com/topic/961140-bad-fps-need-help/#findComment-11654159
