https://linustechtips.com/topic/960909-controlling-fans-speed/
yes you can but 1. they will be all connected to each other meaning you change the speeds of all of them at the same time and you need speedfan or something to control fan speeds.
Main PC
~i7 3770k 4.3ghz Arctic Freezer 33 Esports-Edition
~GTX 1080 MSI AERO (I literally paid £330 for this)
~Samsung 860 EVO 500gb | WD Blue 1TB
~Kingston HyperX 2133Mhz DDR3 4x8gb
~Corsair SPEC-03 Red
Acer Aspire 5338 (2009 Laptop)
Intel Celeron T3000 (Dual-Core @ 1.8ghz)
GM45 iGPU (Mobile Intel 4 Series Express Chipset Family)
Samsung 860 EVO 500GB
Hynix 4GBx2 1066mhz(800mhz)
Windows 10 Pro 64-bit (used to be on Vista)
I have no professionalism if you call 1 year with 3d modelling and unity "professional."
I asked my friend "So how many things do you have rgb so far?" He responded, "The only things that I have RGB is my GPU, CPU cooler, Keyboard, Mouse, Mousepad, Laptop, Ram, Motherboard, SSD, case fans, PSU, cheapo-RGB leds, razer phone 2 and "
https://linustechtips.com/topic/960909-controlling-fans-speed/#findComment-11650753
make sure their current draw dont add up to over 1A
Desktop benching:
https://linustechtips.com/topic/960909-controlling-fans-speed/#findComment-11650756
i use the asus fan xpert. is that ok?
https://linustechtips.com/topic/960909-controlling-fans-speed/#findComment-11650764
That isn't issue, that hub uses external SATA power. Ofc for each of its headers 1A would be limit, but otherwise it doesn't stress mobo header.
@thecraziestowl, make sure to only have PWM fans on that hub. 3pins would go full speed all the time. If you want individual fan control, you need software based controller like Grid or Commander Pro. Or another mobo header.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/960909-controlling-fans-speed/#findComment-11654377
