How much will compressing my drive save space?
Solved by porina,
The zip wont compress more. Videos and images wont compress significantly. pdfs, maybe a bit more there. You could just try them but it depends on their contents. Just be aware you'll likely increase fragmentation a lot by compressing a disk, so you might want to run a defrag afterwards assuming it is a HD. Being realistic, start looking at getting another bigger drive. At best compression will buy you some time.
