So I’m looking to build a pc on a budget, with help of YouTube and a more educated friend, I’ve picked out my parts but I have a few extra questions. One being, will I have good enough supplies to run fortnite, PUBG and some other games on respectable frames and quality? If so and if possible, can you identify the stats? Question two is, will 2gb of VRAM be enough for what my needs and what I want for fortnite and PUBG? How many gb’s will I need? Question three, what can I do to make this better, without spending much more money? What do I need/ do I need a separate cooler?
Thanks so much, sorry if this wasn’t very clear...
PS, besides this I have other builds with slightly different parts at different prices if you would like to see. ALL OF THE CURRENCY IS CANADIAN AS I AM
54ED5409-F5AE-4FD2-86AD-E6536901A7BC.thumb.png.3dc7ebf81db805b87ac987c240b1756c.pngEBE5A47F-BEEB-417E-A076-C3929840F384.thumb.png.a34b08554f30ea6b47f6b3fa6ab15d0f.pngDAA4AE2A-5D32-4427-81EA-8E7D367FB281.thumb.png.1f8523b9ef087feb58c4c26d18f09089.png0DD80023-6B65-48C4-B900-9FBCBB8BD3F6.thumb.png.864f7dc8e7b658cd130a7cb125a292fb.png
https://linustechtips.com/topic/959874-gaming-build-help/
Well the first thing that stands out is B250 is NOT compatible with 8000 series chips. You'll need a B360 or H310 board
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/959874-gaming-build-help/#findComment-11641534
JUST ONE HINT, NEVER WRITE IN ALL CAPS, THERE IS A PLETHORA OF OTHER WAYS YOU CAN GET ATTENTION TO A SENTENCE.
Building on an old system might be worth it depending on the parts and I can't provide any stats for the current listed system but 1050 should run most games at medium to low settings, not sure about PUBG because of how badly it is optimised but the devs say they are in the process of fixing it so it's possible.
List old specs first, please.
https://linustechtips.com/topic/959874-gaming-build-help/#findComment-11641536
1 minute ago, D3addr0p said:
Ryzen also comes with a cooler and I don't think Intel's CPU comes with one.
All non -K series come with a cooler
Prior Build Log/PC:
https://linustechtips.com/topic/959874-gaming-build-help/#findComment-11641546
APU build:
CPU: AMD - Ryzen 5 2400G 3.6GHz Quad-Core Processor  ($209.25 @ shopRBC)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($89.00 @ Vuugo)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-2800 Memory  ($103.99 @ Newegg Canada)
Storage: Team - L5 LITE 3D 240GB 2.5" Solid State Drive  ($62.98 @ Amazon Canada)
Case: Rosewill - FBM-X1 MicroATX Mini Tower Case  ($29.99 @ Amazon Canada)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Amazon Canada)
Monitor: AOC - E2260SWDN 21.5" 1920x1080 60Hz Monitor  ($115.99 @ PC-Canada)
Total: $671.19
Generated by PCPartPicker 2018-08-13 18:08 EDT-0400
AMD + GPU Build:
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($124.99 @ Newegg Canada)
Motherboard: Gigabyte - GA-AB350M-DS3H Micro ATX AM4 Motherboard  ($75.05 @ Vuugo)
Video Card: Gigabyte - GeForce GTX 1050 Ti 4GB Video Card  ($218.50 @ Vuugo)
Total: $791.48
Generated by PCPartPicker 2018-08-13 18:09 EDT-0400
Intel + GPU Build:
CPU: Intel - Core i3-8100 3.6GHz Quad-Core Processor  ($145.99 @ Mike's Computer Shop)
Motherboard: ASRock - B360M-HDV Micro ATX LGA1151 Motherboard  ($70.50 @ Vuugo)
Total: $807.93
Generated by PCPartPicker 2018-08-13 18:10 EDT-0400
Memory: G.Skill - NT Series 8GB (2 x 4GB) DDR4-2400 Memory  ($95.99 @ Newegg Canada)
Total: $799.93
Generated by PCPartPicker 2018-08-13 18:11 EDT-0400
Edit:
Some parts can probably be cut down, just tossed a few together quickly.
Prior Build Log/PC:
https://linustechtips.com/topic/959874-gaming-build-help/#findComment-11641550
The second build will probably net you the best bang for the buck in terms of performance but if you want to start with the APU and then save up for a better GPU you could do that and still get decent framerates on 1080p
Prior Build Log/PC:
https://linustechtips.com/topic/959874-gaming-build-help/#findComment-11641569
First one looks better to me?
https://linustechtips.com/topic/959874-gaming-build-help/#findComment-11641573
I think the second one would do better in terms of raw FPS to start with but yah, first is probably better if OP is okay with maybe turning down some settings at first and saving up for like a 2060 or something later on.
Prior Build Log/PC:
https://linustechtips.com/topic/959874-gaming-build-help/#findComment-11641577
4 minutes ago, Shamusbeaton said:
Yeah feel free to suggest parts, I know jack all about PC’s. I also don’t know what is compatible with what... also if you have a complete build that will run games well please give me a link or something
I would be able to give you links to many systems you can build on PC parts picker or a pre-built if you prefer. What games are you planning to run on the machine and what settings do you want your games to run at while using your new system?
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/959874-gaming-build-help/#findComment-11641580
1 minute ago, Shamusbeaton said:
Well if the first one is better besides the apu , what could I do to enhance it
Like Lurick said just save up for a Graphics card while that current system could still play some titles, Ryzen APU is actually quite good, not graphics card level but close. At 1080P :D
https://linustechtips.com/topic/959874-gaming-build-help/#findComment-11641588
What's your budget?
this is a mid end build including monitor and peripherals
https://ca.pcpartpicker.com/list/pfYRYT
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/959874-gaming-build-help/#findComment-11641607
what I hear I think I’d rather build one?? you tell me.
I would definitely suggest looking for used hardware which would improve the price to performance of your system. What I would do would be get a used system as a platform and make upgrades to it which would be necessary (RAM, CPU, GPU, hard drive, etc). I would look around sites like Craigslist and eBay to see what deals are being offered for used or refurbished hardware as that tends to give better value to the system compared to purchasing new or building a computer with completely new components. Also, @Lurick you have not included an OS in any of the PC parts picker computer lists which you have posted. An OS could cost around 119 USD (for windows 10 Home edition) or more usually and that would be something to consider if you build the system yourself.
        @Boomwebsearch
https://linustechtips.com/topic/959874-gaming-build-help/#findComment-11641626
SCDKEY is a website you can get it for around 20 dollars or be a pirate :D
https://linustechtips.com/topic/959874-gaming-build-help/#findComment-11641629
