What does 4G LTE Module do on a laptop?
I am trying to custom build laptop it have  the option to add Huawei ME936 4G Module
1. So what is it?
2. Are there any better than this module? better speed and config
3. Will there still be a spot for Killer 1550 + BT 5.0?
https://linustechtips.com/topic/959592-4g-lte-module/
It's used for internet access. Just like having it on your phone.
https://linustechtips.com/topic/959592-4g-lte-module/#findComment-11639139
Basically its a M.2 or miniPCI-E card that, attached to appropriate antennas in the laptop, allows your computer to get onto 4G (and perhaps even 3G) networks.  You will need a SIM card from an appropriate carrier.
I personally use the Sierra Wireless modules, rather than Huawei.  Don't know if there's any differences in performance.
The best modules implement LTE-DC, for potentially 200mbit/sec bandwidth on a supported network.
The WWAN cards are installed in a separate slot, so there's still space for a WLAN board such as the Killer that you describe.
https://linustechtips.com/topic/959592-4g-lte-module/#findComment-11639154
So do we need a carrier for that? SIM CARD?
https://linustechtips.com/topic/959592-4g-lte-module/#findComment-11639157
1 minute ago, RedShank said:
Will there be any slot left for WIFI Module?
And a silly question, do we have to put the card in the module? I dont know anything about it SORRY
Most business-grade laptops have 2 slots.  One for WLAN, ie: WiFi cards, and a second one for WWAN like those 4G cards.
So it depends upon the machine you're using.  Remember that a SIM card slot has to be available as well.
https://linustechtips.com/topic/959592-4g-lte-module/#findComment-11639166
Machine is Clevo P775TM1
https://linustechtips.com/topic/959592-4g-lte-module/#findComment-11639168
