Hi, throwaway here, I was wondering which one of the two keyboards is worth more, so:
-I’ll be using them mostly with white lighting (I’ll get the masterkeys with purely white leds if I will get that one);
-I never owned a mech board before;
-the difference between the two is of around 20 euros.
i must admit that I enjoy Logitech’s design (plus I alteady own a Logitech mouse so it would be all in the same style) but the masterkeys is cheaper in the non-rgb variant and I’ve heard a lot of bad things about Logitech switches.
Help me choose I guess?
https://linustechtips.com/topic/959506-g-pro-or-masterkeys-s/
This choice will be 100% decided by which switches you prefer. The Coolermaster comes with Red, Blue and Brown switches and the Logitech with the Romer G switches.
Which one you like is very personal and you should totally go down to a store and try them all out.
For example I personally dislike Red and Romer G switches, very much like Blues and am alright with Browns and in the end chose Browns because Blues were had to come by.
https://linustechtips.com/topic/959506-g-pro-or-masterkeys-s/#findComment-11643274
