Help
Go to solution Solved by Firewrath9,
Consider rx580 8gb, cheaper than 1060 6gb and better imo.
So im planning on building my friend a PC but for all i know his games are Fortnite Call of Duty Black Ops 3/4 and Battlefield 4 ( he just found out BF4 has Multiplayer -_-)
what GPU should i get him , 1060 6gb ? 1070 or 1080 he likes to play on high but isnt 1060 6gb is like 60FPS+ on Medium in 2018 ?
https://linustechtips.com/topic/959495-help/
Well how much does he want to spend? the 1060 is great for 1080.
https://linustechtips.com/topic/959495-help/#findComment-11638411
In those games the 1060 is sufficient for high settings in 1080p. If your friend wants a 144hz 1080p monitor at some point, a 1070 would be the better choice.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
https://linustechtips.com/topic/959495-help/#findComment-11638461
yo i have a 1080 with 1080p 60 hertz monitor , i know i can get more peformence hehe but no more money xD
https://linustechtips.com/topic/959495-help/#findComment-11641963
