Currently ascending from a prebuilt POS, have pretty much everything speced out except for the case.  I've seen the Meshify C, but it's a bit out of my price range.  I'd Ideally like a <80 USD case, preferably white with minimal branding.
Suggestions?
I have too much time on my hands.
https://linustechtips.com/topic/958768-minimal-pc-case/
What are your specs? Depending on your hardware the case choice will be easy.
Best & worst cases for your money in 2018 are:
Best Cases overall
I) Fractal Design Meshify C - Airflow and relatively quiet, best all around case
I) Phanteks Enthoo Pro M / Special Edition (white interior) - Airflow & full water cooling support
I) Fractal Define R6 - Silent with decent airflow
I) Be Quiet! DB 900 (Full Tower) - Airflow and silent
I) Fractal Design Meshify C mini (mATX)
I) Corsair 400C - Only use with low end components, no 1080 / TI
I) Phanteks 350X - Only use with low end components, no 1080 / TI
I) Fractal Design Focus G
Cases that may be worth your money
I) Thermaltake G21 - GPU and CPU cooling issues, modest tweaking
I) Silverstone RL06 / Pro - Mustard/Ketchup wires, Shitty cable management, Poor front radiator support, useless psu filter, stupid ssd layout
I) In Win 303
I) Coolermaster H500 no suffix - if 200mm fans are your thing
I) NZXT H700 non "i" version - Needs to come down in price to be worth it
I) Corsair Carbide 100R - Suitable for low end builds
The worst cases - Do Not Buy
I) NZXT S340/Elite, H500, H440 (everything except the H700) Reason: Poor airflow
I) Coolermaster Masterbox 5
Majority of cases on the market
https://linustechtips.com/topic/958768-minimal-pc-case/#findComment-11632952
RX 580 is a hot temp card and you don't want that near any NZXT case.
If you had a mATX I could recommend the MasterBox Q300L fpr $40 USD. I could recommend some other cases, but they're crap for the money even at $80 (not good enough airflow, stupid rgb, lots of corners have been cut type of thing for the sake of tempered glass.)
Best Cases overall
I) In Win 303
https://linustechtips.com/topic/958768-minimal-pc-case/#findComment-11632961
