I am building my first gaming pc and so I got the Gigabyte H110-MA microATX board with an EVGA 400Watt atx power supply. I found out when opening the power supply and putting it in the case that it has a 4 pin atx 12v connector and a 20 pin power connector while my board has a 24 pin power connector and the 4 pin ATX12v connector is on the other side. Will this power supply work with the board or should I get ana=other PSU? Here are the links to the Board and the PSU:
Board: https://www.amazon.com/Gigabyte-GA-H110M-LGA1151-Intel-Motherboard/dp/B0165YUDTM
PSU: https://www.amazon.com/EVGA-Warranty-Power-Supply-100-N1-0400-L1/dp/B00LV8TZAG/ref=olp_product_details?_encoding=UTF8&me=
Although the amazon saya that this PSU has a 24 pin i checked the model number with the PSu I got and its the same model number but it has a 20 pin power connector.
PLEASE HELP! RESPOND ASAP!!!!
https://linustechtips.com/topic/958349-help/
-= Moved to New Builds and Planning =-
 CHRISTIAN MEMBER
https://linustechtips.com/topic/958349-help/#findComment-11629369
