Hey Guys! I'm thinking about building a brand new gaming PC utilizing some parts I just got. I'm trying not to build anything too expensive so $1000 USD is about my budget for remaining parts. I have compiled a list of parts based on this video, and I'm curious if there are any suggestions for what else I might need or some different suggestions for better parts (SPECIFICALLY the motherboard, hard drive, CPU, and cooling). I mainly play games like PUBG, Battlefield, CS:GO, and older strategy games like Age of Empires II HD. I don't need anything crazy: I just wanted to build my own gaming PC that has good framerate for most games and will last me a couple years.
 Here is a list of parts I'm thinking about using with purchase links:
Case
Corsair Obsidian 750D Fullt Tower $149.99
PSU
Corsair CX 750 watt $59.99 non modular
Motherboard
ASUS H170 PRO GAMING LGA 1151 Intel H170 HDMI SATA 6Gb/s USB 3.1 ATX Intel Motherboard $200?*
Hard Drive
SAMSUNG 850 EVO 2.5" 1TB SATA-6GBPS V-NAND 3bit MLC $230-290
CPU
Core i7-8700k $347.00*
CPU Cooling: ????
GPU
GTX 1060 6GB $280
Single Monitor: one that supports 2k or 4k or at least won't hinder my PC at 1080p max settings
Additional tools:
Magnet/Demagnetizer $5
Toolkit $15
Parts I already have:
GPU
GTX 1060 6GB $280
PSU
24 to 8 pin adapter $7.58
Single Monitor: Dell
Keyboard: Razer Blackwidow
Mouse: Razor Orochi
Headset: Turtlebeaches
*Note: I have not checked the compatibility of CPU with motherboard. I have no idea what to look for in a motherboard and would greatly appreciate feedback or suggestions.
Thanks for your help!!
Edited by sonludus2
https://linustechtips.com/topic/958309-newbie-building-first-pc/
I'd go with:
1. i5 8400 - you're not needing the i7, especially if you're using the 1060.
2. I like Gigabyte motherboards, look at the AORUS Gaming 3 board or Ultra Gaming (other folks will post better ones probably)
3.  Reduce the SSD to 500GB  or 250GB to save money, get a 2TB 7200 HDD for mass storage.
4.  You need memory - G. Skill 16GB 3200Mhz - https://www.newegg.com/Product/Product.aspx?Item=N82E16820231941&cm_re=g._skill_16gb_3200-_-20-231-941-_-Product
Some ideas for you.  You basically built a top end system with a mid-range GPU.  I think you should scale back the build to mid-range to keep it balanced and save money, based on what you play.
If you can, do a pcpartpicker.com list so folks can tweak and report.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Just now, jstudrawa said:
I'd go with:
Some ideas for you.
Okay. I meant to add RAM to the list but forgot. I'll make a pcpartpicker list once I have a little bit of time. Thank you so much!
Glad to help, but also not to NEVER EVER buy something based on my recommendation alone!!!  Others here have so much more knowledge and experience, wait for some more feedback before buying :)
Unless it's a 1440p Ultrawide monitor.  Then buy no matter what :)
OnePlus Ecosystem:
3D Printing:
1 hour ago, sonludus2 said:
H170 boards are not compatible with any Intel 8th gen CPU. Also the 8700K is wasted on anything but a Z370 board, since Z370 is the only chipset that allows overclocking.
If you want to stick with the i7 and have a cheaper B360 board, then I recommend the i7 8700 instead. Otherwise drop down to the i5 8400 + B360 combo.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
I would suggest that you wait for the 9th Gen Intel Processors. Probably get the i7, or the i9 if the budget will allow. I'm very optimistic that it's going to come out this year. Stick with your GTX 1060 for now, then upgrade when the need arises. It's a good idea to get a powerful CPU now, so that you won't spend on a new platform when you upgrade your GPU.
If ever you will be buying now, which I don't recommend. You should be looking at something like this: https://pcpartpicker.com/list/mj8ddX
I'm very much in favor of building a system with a slightly stronger CPU so I can upgrade the GPU later on if I have the need since I got the 1060 free as a gift from a friend.
So you're saying to wait for 9th generation then build something similar to that pcpartpicker list? Also, if I were planning to later upgrade the GPU to something higher than a 1060, what would be a recommended CPU? Would an i5 be enough or should I get something higher like an i7?
What is your budget and what are you using now?  Those are fairly important to figure out if you should wait for Intel's most expensive mainstream processor or not.
OnePlus Ecosystem:
3D Printing:
