Monitor recommendations
Krosis
Hey guys,
I am looking for a new monitor with the following features:
  • 120 Hz or higher (I have never experienced more than 60hz before)
  • AMD FreeSync - I have a RX 580
  • 23 inch or bigger
  • VESA compatible (preferable, but not necessary)
  • As cheap as possible
Thanks!
CPU: AMD Ryzen 5 5600X | MOBO: MSI B450 Tomahawk GPU: AMD Radeon RX 6800XT | RAM: GSkill Trident Z DDR4 3600Mhz | PSU: ADATA Core Reactor 850W 80+ Gold | CASE: Fractal Design Meshify C MONITOR: LG 32UL500-W 4K 60Hz, Gigabyte M27Q 1440p 165Hz
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
Maybe either AOC G2460PF or Acer XF240H. Either of them has everything you asked and they're not overly expensive.
btw the color is pretty bad on both model. If you really care about good color production then get Samsung LC24FG73 (it's more expensive ofcoz)
Primary PC
CPU: AMD Ryzen 7 3700X | M/B: Asus ROG Strix X370-F | RAM: G.Skill TridentZ RGB 3200MHz 32GB | GPU: Asus TUF RTX 3070 8GB GDDR6 | SSD: Samsung 960 Evo 250GB | HDD: Seagate Barracuda 4TB x2 | Power: Thermaltake Toughpower 80+ Gold 650W | Sound card: Creative Sound BlasterX AE-5  | Case: NZXT H500 | Cooling: NZXT Kraken X62 | Display: Samsung CHG70 27" 1440p 144Hz QLED
Secondary PC
CPU: AMD Ryzen 5 5600 | M/B: Asrock B450M Pro 4 | RAM: Kingston HyperX Predator 3200MHz 16GB | GPU: Asrock RX 5700 8GB GDDR6 | SSD: Crucial P1 1TB | HDD: WD Black 1TB | Power: Coolermaster Masterwatt 550 | CaseAerocool Cylon Mini | Cooling: BeQuiet Pure Rock Slim 2 | Display: Samsung CFG73 24" 1080p 144Hz QLED
Thanks for reading
