I am looking to do a targeted upgrade of my PC to get the most bang for my buck and, per Linus' recent video, thought I would post here to try and preempt bottlenecking issues. I am probably looking at either a GPU or CPU upgrade. I mostly use my PC for gaming and hit 1440p resolution at 60-120 fps depending on the game at mid-to-high graphics. Mostly I want to upgrade just to keep up with new offerings and keep my build from getting too dated.
Current components include:
  • Intel - Core i7-4790 3.6GHz Quad-Core
  • MSI - Radeon R9 390 8GB
  • Gigabyte - GA-H97M-D3H Micro ATX LGA1150 Motherboard
  • 4x4GB G.Skill - Ripjaws X Series DDR3-2133
  • Raidmax - Vampire 800W 80+ Gold Certified Semi-Modular ATX Power Supply
  • Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive
  • Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
I've been thinking getting a Ryzen CPU would be a good step, but haven't thought much further than that. All thoughts/input welcome! Thanks!!
https://linustechtips.com/topic/957752-what-should-i-upgrade-first/
1070ti/1080 will do
Desktop benching:
6 minutes ago, GoldenLag said:
GPU is what is needed a upgrade. A 1070/Vega 56 will do. Depending on if you have freesync or not.
The little extra for the vega is worth it for freesync
I do have freesync so I'll definitely look into the Vega. Thanks!
