Hello i got a problem with ram capacity bios shows 16384 MB of ram but windows 32GB and 16GB usable. I tried like to flash to latest bios remove the limit  size of ram form windows reset the SPD change ram slots to A1 B2 and A2 B1 with different rams all work, windows is the professional version to limited by that. Any ideas how to fix that?
CPU : ryzen 1700x
motherboard: asus croshair vi hero
GPU:nvidia 1080ti
Ram: FURY Memory Black - 32GB Kit* (4x8GB) - DDR4 2666MHz
https://linustechtips.com/topic/957388-ram-capacity-issue-on-ryzen7/
CPU : ryzen 1700x
GPU:nvidia 1080ti
you got either bad RAM, or bad DIMMs.
Linux Daily Driver:
CPU: R5 2400G
Motherboard: MSI B350M Mortar
RAM: 32GB Corsair Vengeance LPX DDR4
HDD: 1TB POS HDD from an old Dell
SSD: 256GB WD Black NVMe M.2
Case: Phanteks Mini XL DS
PSU: 1200W Corsair HX1200
Gaming Rig:
CPU: i7 6700K @ 4.4GHz
Motherboard: Gigabyte Z270-N Wi-Fi ITX
RAM: 16GB Corsair Vengeance LPX DDR4
GPU: Asus Turbo GTX 1070 @ 2GHz
HDD: 3TB Toshiba something or other
SSD: 512GB WD Black NVMe M.2
Case: Shared with Daily - Phanteks Mini XL DS
PSU: Shared with Daily - 1200W Corsair HX1200
Server
CPU: Ryzen7 1700
Motherboard: MSI X370 SLI Plus
RAM: 8GB Corsair Vengeance LPX DDR4
GPU: Nvidia GT 710
HDD: 1X 10TB Seagate ironwolf NAS Drive.  4X 3TB WD Red NAS Drive.
SSD: Adata 128GB
Case: NZXT Source 210 (white)
PSU: EVGA 650 G2 80Plus Gold
Just now, Axelatron said:
@MedievalMatt ok thank you so i will try to check the ram on others pc and their ram on my if that is ok i would have to send
back motherboard right?
Yeah more than likely either rma the ram or motherboard depending on which is bad
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
Something similar happened to me.  My Wife's PC would register 12GB usable, and 16GB total (had a 16GB kit in it) in windows for the longest time.  the Bios read the full 16GB though.  she would get the occasional random BSOD, and no matter what i did windows wouldnt get the last 4GB.  swapping sticks into different slots and nothing seemed amiss.  after about a year of this, the RAM stick finally actually died outright.
seems very very similar to your issue.
Linux Daily Driver:
CPU: R5 2400G
Gaming Rig:
Server
CPU: Ryzen7 1700
GPU: Nvidia GT 710
SSD: Adata 128GB
yes probably would be that  i will try tomorrow and then see which one is faulty
1 hour ago, ReHWolution said:
Actually, it could also be the CPU, with a damaged pin for those RAM slots. But yeah, it seems like it's a motherboard/RAM issue.
thanks a lot after i will try that then i guess i got to sent my pc to a technician to check it for sure and sent back the faulty one
