My current build! SLI with another 1080??
Jwilks
Hi everyone, I'm new to the forums and thought I'd add a build log here to show everyone my build!
CPU: i7-7700k
Motherboard: MSI Z270 XPOWER GAMING TITANIUM LGA 1151
RAM: G.SKILL Trident Z Series 32GB (4 x 8GB) 288-Pin DDR4
GPU: EVGA GeForce GTX 1080 FTW GAMING, 08G-P4-6286-KR,
Case: Cooler Master HAF XB EVO
Storage: 1 4tb 7200rpm drive, with 500gm kingston SSD
PSU: CORSAIR AXi Series AX1200i 80 PLUS PLATINUM
Display(s): Two Acer S231HLs and 1 Dell S2417DG 24" QHD 2560 x 1440 144Hz Gaming Monitor
Cooling: ENERMAX ETS-T50A-WVS Twister Aluminum 120mm
Keyboard: Razer Blackwidow Chroma V2
Mouse: Mionix Naos Qg
Sound: CORSAIR Gaming VOID PRO RGB Wireless
Operating System:Win 10
Should I SLI with another 1080 or am I good for now?
Looks great!
I think one 1080 is completely fine for now but if you want to go even further in performance you could switch to i5-8700K costs less, does more
Looks nice, no ketchup and mustard cables.
The fan is supposed to be on the other side of the cooler though isn't it? pushing air through the cooler instead of pulling. Did the cooler fan not clear the memory modules?
Yeah I had to put it that way because the ram would've gotten in the way. I might go with liquid cooling in the near future if there's enough room, or go with a another case.
