Hello. My pc config is i3 4160(3.60 Ghz) 8 gb DDR3 Ram, Gigabyte H81M-S2PV and a Gigabyte windforce GTX 1050ti. Now most of the game's i play like GTA 5,Farcry 5,Metal Gear ,just cause 3 and mostly every game i never get upto 30 Fps, and sometimes the frame rate falls down to 10 or low then i have to wait a few moments then it goes back up. I'm now playing pubg Mobile using the emulator im getting 22-27 fps , where my friend with the same 1050ti gets 60 fps he just has a 6th gen i3 and 8 gb ddr4 ram. So my question is do i need to change my cpu or the whole system to remove this problem.
https://linustechtips.com/topic/956557-need-help-with-bottleneck-problem/
JC3 and Far Cry 5 are both pretty damn demanding.
As for GTA, not sure what's going on there.
Metal Gear Survive?
Some of this sounds more like an issue more towards drivers or other software than the hardware configuration. GTA V and Meta Gear Solid V (I'm assuming) shouldn't be hard to get 60 FPS on that setup.
