Hey guys, I am building a pc (mostly from used parts) and was wondering that what will bottleneck my pc.
The setup is going to be Intel Core 2 Quad Q9550 (later maybe a bit overclocked), Gtx 770 2gb, 600W psu, 8gb ddr2 RAM, Asus p5k motherboard, Kingston A400 120gb ssd
https://linustechtips.com/topic/956306-what-will-bottleneck/
CPU will bottleneck the system.
The oldest generation CPU's on intels side i would recommend is Sandybridge (2nd gen). For example a 2700k.
While there is now a noticable difference between the performance of a 2700k system and a 8700k system, the Sandybridge generation is still perfectly capable of handling modern titles. So if your going used, the oldest you want to get is Sandybridge (2nd gen)
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/956306-what-will-bottleneck/#findComment-11611794
