1 minute ago, fpo said:
Personally I use a Clorox cleaning wipe. The kind that’s safe to use around the house.
I just unplug it and thoroughly wipe down my Logitech G502.
Does it clean it Completley or leave a lot of dust and stuff inside it ?
https://linustechtips.com/topic/955937-please-help-me-d/#findComment-11608609
Just now, valdyrgramr said:
Depending on the material that might scratch the shit out of the paint, but my main issue with water is possible damage if you're not careful.
Hmm , i mean i spillied Cola on it once and to be honest after i washed the side with the Cola its WAY MORE black than the part that i didnt wash
https://linustechtips.com/topic/955937-please-help-me-d/#findComment-11608612
18 hours ago, fpo said:
I don't take mine apart. I just clean the outside.
Well i decided to wash it , and i scrached it with a soft brush andddd Yeah good results , All the pad is DARK BLACK and still has the stickiness to the table and god its so freshing to move the mouse on it , its like i bought it again
https://linustechtips.com/topic/955937-please-help-me-d/#findComment-11610862
Usually some light detergent with a brush or cleaning cloth using some warm water does a good job.
-Moved to Peripherals-
https://linustechtips.com/topic/955937-please-help-me-d/#findComment-11610977
I just put water i think it was cold and started brushing not to strong so the cover wont come off and thats it
https://linustechtips.com/topic/955937-please-help-me-d/#findComment-11611006
