Hey...am a Nigerian and i have always wanted to build a Gaming PC.. but unfortunately, things are too expensive down here
I bought ;
A Dell Optiplex 760 With a C2D E7200@ 2.50ghz for about $125
A ddr2 ram 3Gb (1x3) @800ghz for about $10 each
And A Radeon hd 4890 2Gb for about $100 (used)
(Naira was converted to Dollar)
With all this, my gaming experience is still very poor
And trust me..making/getting upgrades are 'Very Expensive' Here.... I really need help on what to do
Thanks
https://linustechtips.com/topic/955654-need-help/
I bought ;
Thanks
Turn down settings to low in games. Should help. If the game you're having a poor experience with it allows mods, try find performance boosting mods for it, for example minecraft has a performance boosting mod called Optifine.
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
https://linustechtips.com/topic/955654-need-help/#findComment-11606618
I bought ;
Thanks
Anything on the used market? Unless you're planning to make a platform upgrade in the near future, no point spending big bucks on a new current gen GPU.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/955654-need-help/#findComment-11606624
Thanks alot but with low setting, i struggle to 30fps
https://linustechtips.com/topic/955654-need-help/#findComment-11606625
What game are you trying to play?
https://linustechtips.com/topic/955654-need-help/#findComment-11606626
Honestly....am new to PC gaming
Bt so far... I purchased COD (MW3)
FarCry3
Watchdogs 2 (totally unplayable)
Watchdogs 2 I'm not surprised you're getting bad frames in that. It challenges modern hardware to some extent.
FarCry3, turn off vsync if you have it on, lower your graphics settings to the lowest you can.
COD MW3 idk about, probably just too demanding for your hardware.
https://linustechtips.com/topic/955654-need-help/#findComment-11606650
Thanks a lot am really grateful
Dunno if you've got any recommendations For a fair/good gaming pc?
https://linustechtips.com/topic/955654-need-help/#findComment-11606663
9 hours ago, Psittac said:
I would say that you should look for games that will run on your hardware instead of making your hardware run so hard.
Here's a list of games that should run on his hardware:
Fallout 3
The Elder Scrolls 4
The Elder Scrolls 3
The Elder Scrolls 2
The Elder Scrolls 1
GTA 3, vice city, san andreas
Robocraft (its free on steam)
Minecraft
Halo CE
COD MW1
Loads of others out there that would play but these are just my suggestions.
https://linustechtips.com/topic/955654-need-help/#findComment-11607640
-Moved to New Builds and Planning-
https://linustechtips.com/topic/955654-need-help/#findComment-11607659
Fallout 3
The Elder Scrolls 4
The Elder Scrolls 3
The Elder Scrolls 2
The Elder Scrolls 1
Minecraft
Halo CE
COD MW1
Thanks a lot
https://linustechtips.com/topic/955654-need-help/#findComment-11614338
3 hours ago, Elvis Caesar said:
Thanks a lot
You're welcome. Happy gaming :)
https://linustechtips.com/topic/955654-need-help/#findComment-11614857
